royal4
I searched on all of the above and haven't found a solid answer.
ok, (my engine == 150XB not in water)
I know you use the motor connection to flush the motor without running the engine.
You use a motor muffler, if you want to run the engine.
my question:
1. proper name: telltale? tell tale? tell tail? or pee-hole
2 Should you get water coming out the tell tale when running the engine with garden hose hooked up to muffs?
Today I didn't get any but I never ran it very long just in case you're supposed to.
I've read many things online, tilt motor up, this, that, use garbage can, yada yada yada...
so what say you.... do you get water coming from the telltale when using muffs and if yes, how long does it take after starting the engine.
Do you use a motor muffler and if so, round? rectangle? dual (water to both sides) and why?
Garden hose full on, half on?, or ?
thanks,
Royal
add: It works fine in the water after about 10 seconds if that.
my question:
thanks,
Royal
