If its only the tower , check the wires ,connections and connectors ,or its possible the output from the radio could be bad . I would start under the helm and work my way to the speakers .
If you are the original owner it should be under warranty .
So i know the tower on my boat has a separate plug under the helm for tower speakers. If both of them went out at the same time id check to see if the plug came undone. If it didn't id then check if they are wired to the amp or head unit. If you turned off the internal amp on your head unit that could have cut power to the speakers. Bennington doesn't really wire these audio setups for best performance so Id be curious as to how yours was setup.
