It does make a differnce and will help.so, question...
mine is on the bracket as shown, and parallel with the tube. That said, generally with the weight of the motor and folks on board, the tubes sit at an angle in the water... maybe 10 degrees or so. should the transducer actually be tilted to account for that such that it's more parallel to the bottom? how much difference does it make if so?
Forgot to add you can get engine data on this as well with an N2K connection.
i'm all about risk... lolIt does make a differnce and will help.
IF…if you combine that with lowering the transducer slightly lower than the bottom of the pontoon, that will help the most. But angle certinaly does improve reading at speed. You eliminate cutting out due to poor angle, and then are left with it just cutting out if in turbulant water (which lowering below the tube often eliminates, but then also puts the transducer at risk, so…).
220, 221... whatever it takes...
