Currently my Trim Motor Gage only operates between 3/4 and fully down. (E-tec 90HP)
Motor trims up fine but gage stops in the 3/4 down position.
Any suggested starting point for troubleshooting ? )
Tilt your engine completely up and look for a stuck plastic lever in the upper left corner that is spring loaded. Spray with silicone spray to displace water , salt, debris. Work it with your finger or screwdriver to loosen it up. Please use caution in that tight space. Good Luck ️️
