lostpacket
- Messages
- 71
- Reaction score
- 61
I'm hoping to solve two problems we're having, and I think using aluminum extrusions might work the best because their light, strong, weatherproof, and flexible. I'm looking for opinions or possible alternatives.
The first problem is our cooler and wasted space.We take the cooler and and store it here which works well as we don't use this door but we can't put things on top (towels, shoes, dry food) so I want to build a little shelf that the cooler sits on and leaves space open at the bottom. The shelf would just sit there and the cooler would basically hold it down. I would fit it perfectly to this space and being aluminum I could leave it there and wouldn't have to worry about rust.
The second issue is the changing area that we just use for storage. Again I want to build out a teired system where maybe there is a bottom section that the anchor could slide into and then a thing top part for noodles and toys. I could use wood but that's heavy and ugly, I could weld something for cheaper but that would add weight and have to worry about it rusting. The Ai would work well here to as I can git it perfectly and it would be modular.
Thoughts? Ideas?
Thoughts? Ideas?
