You are the perfect candidate for the Blue Sea SI-ACR switch! Charging both batteries on the run but isolation to prevent your crank getting drained.I get frequent electrical error messages - have not confirmed but after testing conclude - one of the batteries is direct wired to the power steering, so after a long day if I am not using that battery the system picks up the low voltage and creates the error. When I switch to the second battery (at which point generally I have to switch to 1+2), the issues goes away, both batteries get charged, and I am good for another day out.
Thank you - added to the project list! Seems like a no brainer as far as being a critical part of a good 2 battery system.!!!!You are the perfect candidate for the Blue Sea SI-ACR switch! Charging both batteries on the run but isolation to prevent your crank getting drained.
You will thank me later, trust me!
