SirVive
I am a first time pontoon owner with a used 2013 22SFX with 90 Yamaha motor. I have been in the water 3 times now (on the boat) launching on the Bogue Falaya River running from Covington, LA to Madisonville, La at Lake Pontchartrain. I am already a devoted follower of this forum and its wealth of information for tooners. I have no experience with large boats; only 14-16 ft flatboat fishing rigs. I have learned a lot from this forum and YouTube videos and some other research in my two months of ownership. We are loving the boat as we learn how to do it. I am getting about 26+ mph per my handheld GPS at about 6100 RPM which I understand is about where I should be. I replaced my beat up prop with a new identical one which smoothed out the engine (13" x 13.8p). At about 20mph or greater, I am getting water coming in thru the openings thru the deck where the front (upgraded) fishing seats are mounted and around the base where the table is mounted. From the paperwork, I think these items were installed with the original boat order. there is no protection at all under the deck where these holes go thru. I am attaching some photos. My questions are: Should there be some factory shielding around them? And is this a normal looking install method under deck? I also note that there are splash guards only on the 2nd, 4th, and 6th cross members underneath. Warranty on the toon is in process of being transferred by a dealer for me, and I have extended the Yamaha motor warranty for three years. This issue should be covered by warranty. I am going to have the dealer install a trolling motor and look at these issues after the July 4th holiday. Local dealer is not the original seller but has serviced the boat for the previous owner. I was considering adding under deck sheeting myself even before I noticed the leakage. Thanks.
