lakelifeMN
Keep us posted on how things go and what results you see.Thanks
I agree your problem is not just a prop swap. I assume your speed is GPS? Second-check and see if your dragging an anchor or big tree root. Third trim down all the way and try it. My boat will run within 1-2 MPH with trim all the way down, trimmed to 30% will gain me 1-2 MPH and relieve the motor some.Take a picture of a mounting holes on your transom. I don’t think this is purely a prop situation. I believe mounting height will be ultimately something to look at as well. I don’t believe a prop will change the speed by 10-15 miles an hour. The prop that is on there is pretty close to what I think you will need.
Agree. Even if you change the prop your not going to pick up 10-15 mph. Are you trimming the motor up? I have a 25R w/250 merc. 16” prop 44 mphTake a picture of a mounting holes on your transom. I don’t think this is purely a prop situation. I believe mounting height will be ultimately something to look at as well. I don’t believe a prop will change the speed by 10-15 miles an hour. The prop that is on there is pretty close to what I think you will need.
43 yesterday on the 22LSR 175Vmax
way better than what anyone would have thought I would have got, including me. Only drawback, a little over 2 miles to the gallon on fuel
His specs are in his original post .What prop are you running?
2021 24LX ESP .125 300HP What to Expect WOT?
Just past the 20 Hour break in on 2021 Yamaha 300DEC which sits on back of a 2021 24LXSB with ESP .125 Toons. Last night was a great night with a long run to Put N Bay island to listen to Blake Shelton concrete from the boat. First time I had a long run with WOT and was super happy with the...club.benningtonmarine.com
Thank you. I’m just trying to figure out what to expect MPH wise and have installed on mine with a 200 Vmax. I have the same boat on order. Don’t mean to jack the thread either.VF175, so I'm going to assume the Reliance SDS 14.5x15 prop.
DejaWiz is correct with my prop, engine mounted in the lowest hole.Thank you. I’m just trying to figure out what to expect MPH wise and have installed on mine with a 200 Vmax. I have the same boat on order. Don’t mean to jack the thread either.
My SHO 250 has the same operation of water flow. Takes just a little bit for it to start and the stream is not a heavy high pressure stream. But I don’t have any overheating issues at the motor stays right at about 120° no matter how I run itThanks for the data, I for sure have something going on since last trip out was the wife and I, 40 gallons fuel, flat water, zero wind and WOT was 32MPH
The engine sounds fine, the only thing I did notice was the motor takes a few seconds before it start to pee and the flow is not as strong as it should as my other 150HP.
I'm aware of weak pee flow but thinking that is on OLDER issue![]()
