DVW
- Messages
- 243
- Reaction score
- 462
Need prop recommendation for my 22SXL project. The boat description can be found in the Do-It-Yourself section of this forum. During development of the boat I went thru 4 different aluminum propellers. Now that the project is more or less done I want to switch to a stainless prop for a little more speed. I now have Mercury Nemesis 4 blade aluminum prop 12.5” dia X 19” pitch with Yamaha F115 power. The current top speed is 50 mph at 6200 rpm (std 2.15:1 lower unit). As you can see from the attach photo the so called cavitation plate is slightly exposed at speed. Despite this as I trim the motor up to achieve top speed that speed is limited by porpoising not aeration. Any help would be appreciated.
