Todd & Amanda
While we wait for our new boat I'm looking at options for upgrading the sounds system. We previously had wet sounds (aftermarket installed system not the factory upgrades) and we loved it. Not previously having a Bennington I don't know what I'll find under the dash for a power source. The boat will be a Q series with the Mercury Verado, will there be any type of 12 volt cable under the dash heavy enough to supply an amplifier or will I have to run wiring somehow? Also since this boat will be a swing back it has lots of room under the rear seating for a subwoofer and amp which is easy to access the batteries to supply the amp. Only issue on the sub located under the rear seating will be running the RCA cables to the amplifier, any suggestions?
