Kells
It looks like this is an option on the 2014's and I would really like to use the space there. Here are the pictures
On my 2013 there is a wood cutout wrapped in vinyl mounted there, it was halfway loose and I noticed the corner of it sticking out farther after a day of boating so I gave it a light pull and the whole thing came off! It was just stuck to the panel with some form of double sided marine grade velcro strips 2" x 5" long. both sides of the strips were stuck to to the removable panel because it looked like the adhesive against the aluminum panel had failed.
Behind it was a solid piece of gloss black aluminum siding (without the ripples). Looks exactly like the picture above without the brackets and latch.
Does anyone know if I were to cut this out would it be wide open like it is in the picture above? If so I can proceed with this project.
I just don't want to find out there was some support beams running along the area I would like the cutout.
Any input would be appreciated.
Thank you
Thank you
