Ignition key mechanism turns
jay21
looking for some suggestions on how to fix key mechanism. It takes two hand to turn the boat on or off as the start mechanism is so loose. On our 2019 22G the key is below the throttle engagement for forward and backward so there is no way to get to the back side of the start mechanism. I have tried holding the key and turning the outer part but nothing works.
Any ideas?
Thank you,
Jay
If you can't access the back of the switch,let your dealer fix it under warranty.
Do you have a speaker or cupholder you can remove to reach it?
I had the same issue last year and ended up replacing it with a new key mechanism. I had access from under the helm though, just had to squeeze under it!
