Mooring Cover Question .
Jack M
Indian River ,Michigan
Are the vents in the Mooring Cover ,removable ?
The one on my bow is located correctly it appears that there is a hole in the cover ,but it looks to me that the vent just needs to be moved to the proper location .
Thanks
Yes, the "inside" collar should unscrew from the "outside" ....
I actually had to tighten mine when I got it. They come apart very easily
I did get them apart ,they were still stuck once the collar was removed .I did have to pry them slightly .
Two of the four were were more than half off the reinforcement patch ,can't believe they let them out like that . .MIght be part of the reason I had so much water on the floor two weeks ago
Either way case closed, its corrected .
