I have a 22 ft SSI with Eliptical Sport Package. The engine is a 150 Yamaha 4 stroke model F150 TLR. The boat was set up by the dealer but I have now moved it to my lake house 12 hours away. Wide open the boat is doing about 45 mph with the Tach reading 7,200 RPM. I am told that the motor RPM cut out should kick in and that this should not happen. The limiter does not kick in????? and the other explanation I get is that the Tachometer is set up incorrectly. I understand that going inside the console there is something on the tach to set it up for my engine. Can you give me some suggestions.
Also can you give me some prop ideas for the most efficient prop size and pitch etc.
Holeshot ????????
Maximum speed ???????
Fuel efficient ???????
Thanks
jmermo2004
Holeshot ????????
Thanks
jmermo2004
