Rssuttle
- Messages
- 77
- Reaction score
- 36
Bear with me. My Bennington has two fishing seats in back with the livewell that sits in front motor. The livewell has two outrigger holes to install rod holders. I’d like to use those in livewell but they don’t sit out to the side of pontoon. I’d like to use the two out rigger holes to put two straight pipes into and they stick up over livewell 12”-18”. Then run a pipe horizontal across the the two pipes in livewell to the sides of the pontoon. Maybe 18” to 24” out on each side and mount rod holders to troll for striper. Has anyone seen anything that might work. For now im using plastic mounts that connect to rail with no drilling into rail. There railblazer I think there called. There just not heavy duty enough.
I’d like the two poles coming out of live well to have a circle mount that I can slide the horizontal rod through it and just tighten.
Anyway I hope you can understand what I’m trying to do. Thanks
I’m attaching a picture. Something like this with the two rods going down into the the live wells already holes set up and with only like 2-3 rods able to hook to it.
