speaker switches
Z
speaker switches
Top switch works interior speakers and bottom works rear deck speakers so that I can have all, none, inside or outside on depending on what is going on.
Great idea !!! How'd you wire connections being numerous speaker wires?
I have a 4 channel amp running the inside speakers and the two rear are running off the deck.  Used a DPST switch (bottom switch) for the rear and it basically cuts the neg of the right and left  rear deck speaker and the front switch just cuts the remote (blue) wire to the amp.  You could use a 6 ch amp and amp them all but it gets plenty loud.  You could also use a 4 channel 2 ohm stable amp and run 2 channels at 2 ohm but you cant use the remote wire to cut off and on sets of speakers, you would have to use one like my rear switch on the speaker wires themselves.
cheapo mods
zyvin
