2014 22SFX Fuel, Tach, & Trim Gauges all DOA at same time.
ToyjoHa
Checked √:
Grounds √ok
5amp Breaker (under the switch) √ok
Switch √ok
My next thought is the 10amp inline fuse on the common purple wire leading to the engine ignition positive (+) from each gauge.
Where is it located? Under the cowl? In a harness by the engine? Or elsewhere?
(see the attached electric schematic diagram as provided by the good folks at Benny)
  • S Wiring Diagram.pdf
My guess would be a main fuse back by the battery or inline from the battery under the helm.
