2015 Etec 115
Just taking out of storage after 8 months. Fires immediately but sputters and stops. Did this about 20 times then gave up till I find a solution……what would you check first??
Indoor or outdoor storage? First thing I'd look at is possibly a block fuel filler vent hose. Is your fuel primer bulb staying hard or does it get "sucked" flat when the engine stalls? If so, then you have a clog somewhere causing too much vacuum and most likely a clogged vent
Sounds like the outside fuel/water separator (Yamaha) is clogged or need’s filling. Many people forget to fill up the canister before re installing. Good Luck⚓️⚓️
Check the kill switch where the kill lanyard connects. Operate it and put it in the run position. Check that the battery switch, if you have one is in the correct position.
