I have 25R tri w/ esp (32”) center tube. 250 v8 mercury. 14.5 x 17” Enertia prop. Max rpm 5700. 43.5 mph max speed. Should it be doing better or is this it?
I would say that is a good number given the weight of the R line. Your Mercury has a rev limit of 6000 so you're very close to that, and your calculated WOT slip is around 12% which is also excellent for a heavy pontoon.
There are some Performance Bulletins on both Yamaha and Mercury sites to help compare your numbers to other boats and propellers (Yamaha has more Bennington models to choose from) but real users here would be the best comps if you can find a few. I would venture you'll be right in the mix if not in the upper half or third of performance.
How does it feel from a hole shot standpoint?
That seems to be the perfect match. I was not aware Enertia made a 14.7 x 16.2022 ,23ft QCW SPS Plus ,250 Verado 14.7 X 16 Enertia 44.6. Rpm's 5950 . 2 people full tank
That seems to be the perfect match. I was not aware Enertia made it 14.7 x 162022 ,23ft QCW SPS Plus ,250 Verado 14.7 X 16 Enertia 44.6. Rpm's 5950 . 2 people full tank
I'll take a pic next time I'm outThat seems to be the perfect match. I was not aware Enertia made it 14.7 x 16
