Hold our horses here.I also looked at and in my center toon and it had maybe an inch and a half of water in it. I’m thinking that is normal due to it being open in the back.
Where at in the center pontoon are you seeing this water? Rear transom area? Do you have an in-pontoon center storage compartment and it’s in there? OR did you actually check somehow the sealed compartments of the center pontoon and it is water in there?
This could be important. Rear transom area is normal and drains out. If in in-floor center storage compartment, you need to turn on your bilge pump and pump that out. Should be a switch on the dash for that. IF you have actual water in a sealed center pontoon compartment, that will impact performance and means you have a leak somewhere. It would also start impacting performance. That would need to be taken care of differently.
