Accessing interior LED light wiring
Dewitt492
I have a 2008 2275 qxi. The LED light mounted on the helm doesn't work and I'm suspecting that there is a loose wire / connector. I don't see how to access the wiring for this light unless I remove the panel which has some type of plastic clips. Has anyone removed these before and if so do you simply just pull out on the panel? I can't see the ends of some of the clips when I pull the seat back on the forward lounge seat (see attached pic).
Anyone?
Those black things are push clips that get installed from the other side. Pushing them out will not help you. All the wiring on the helm on my boat is behind a board that unscrews.
