Been out with the wife and child and performance has been ok. 32-34mph 5800-6000rpm
Today however we loaded the tritoon down to its max 12 person 1650 pounds, it seamed the prop was slipping consistently didn't matter where people moved on boat.
I could not trim up the motor at all had to stay down. Normally I can trim up to 1/3 before blow out with just the 3 of us..
engine was loaded down 4800 rpm at 23 mph
Specs are 22 ssrx tritoon 115 Mercury CT spinning a Black Max 3 blade 15 dia. by 15 pitch prop.
Been wondering about the Spitfire 4 blade props, I m not as concerned with top end just need a better grip, in turns ect.
Would a person run the same pitch or drop down to 13 or 14P when switching to 4 blade.
the toons are getting some algae on them boat has been in the water at slip since May 10th.
I'm probably going to pull home this week and wash them down.
