Greetings, hoping someone can help me out with some measurements. Recently purchased a used OEM bimini (frame, top, hardware) off a 2016 Bennington 24 SSRX. Bimini is 8 1/2 ft wide and ~10 ft long. I'm going to add this to the front of my 2875 RLX. Problem is I'm not having luck getting info on the appropriate distance to mount the front and rear arm attachment points to the pontoon fencing. Anyone have info on the distance the front and rear mount points need to be from the center mount point of the bimini frame?
I've contacted Bennington multiple times - no response and have been searching the web with no luck.
Info would be greatly appreciated if someone has one and can give me the measurements!
Thanks much
Thanks much
