Can't Read Gas Tank Gauge/Sending Unit For In Floor Fuel Fill
rbtnt
I have a 2020 Bennington 23SSRXPSG with extended deck and the rear in floor fuel fill. Next to the fuel fill on the tank is a mechanical gauge that in also the tank level sending unit for my Simrad.
The mechanical gauge is plastic that is not clear enough to read the gauge numbers this year. The sending unit part of the gauge works fine. I use this gauge when filling my tank or if I want to check my tank level without removing the cover, turn on the battery switch and wait for the Simrad to startup.
I removed the gauge/sending unit (2 screws and a watertight connector) and took it to the dealer to see about having it replaced by Bennington under warranty. The dealer sent a picture of the gauge/sending unit to Bennington and Bennington responded that they have never installed this type of gauge/sending unit. The unit has the same type Deutsch DT04-2P connector the Bennington frequently uses.
My question to this group, do any of you with the rear in floor fuel fill have the same gauge/sending unit that I have? Pictures are below.
If you have this type of gauge/sending unit in your Bennington, please let me know along with the year of your boat.
Thank you.
The first picture is the gauge/sending unit and fuel fill.
The second picture is the gauge/sending unit. Notice that you cannot read the numbers - 1/4, 1/2, 3/4.
The third picture is a close-up of the gauge/sending unit, but the numbers are nearly illegible.
The forth picture is what a new gauge/sending unit looks like.
I have the Direct fill , but my boat ( 2022 QCW ) is still in storage due to the flooding here .
Ill look through my old pics later
Here are the 2 pics I have . The 1st pic ,you can see I was missing a clamp .
Thanks for the photos. You have a sending unit without a gauge.
My 2020 , had the same Direct Fill set up and did not have a gauge either .
Thanks for the feedback.
Here is the phone number for Bennington , 888 906 2628 if you would like to contact them yourself . If you do call, have your Hull ID .
You're Welcome . Good Luck ! Let us know what you find out .
Update: I received a call back from Bennington this morning after I left a couple of voice mails this past week. The customer service rep knew exactly what I was talking about as he has worked on the production floor. The rep said I should contact my dealer and have the dealer send an email to the rep with the details and that I should receive a new gauge in 2 - 3 weeks.
I will post again once I receive the gauge.
Update: I contacted my dealer again right away, who contacted the Bennington Customer Service Rep (CSR) that I talked to. The CSR said that Bennington has never installed this gauge/sending unit. The CSR said that he asked his admins and they said Bennington did not install this gauge/sending unit. Therefore it will not be replaced under warranty.
My next step is to contact the General Manager at the dealership where I bought my Bennington and let him know how Bennington handled my warranty claim.
I can understand if Bennington didn’t install it, that it wouldn’t be covered by the warranty. Did you purchase the pontoon new or used. Maybe the dealer installed a non-Bennington part for some reason.
I ordered the boat with lots of options and bought it new. It was the first boat with a direct fill tank ordered by this dealer. The dealer is a high volume Bennington dealer. The service department said they did not install the part and would not have a reason to install it.
Glad the dealership stepped up.
Such a strange situation, hopefully one that you will never have to worry about going forward.
A good dealership sometimes is just as important as a quality manufacturer. I can see why people say pick the dealership before picking a brand of motor.
That is a strange situation all the way around with you being the original owner. Glad to hear the dealership got you taken care of. I’ve really never heard of this being a problem/issue, so I would think you are absolutely fine moving forward.
