Suggestions?This. ^^^
I would not feel comfortable without it if it might be needed to ensure completing a trip. What's the difference between the fuel in your tank and the fuel in a separate can?I would not feel comfortable with extra gas onboard.
It is "fuel in a seperate can".I would not feel comfortable without it if it might be needed to ensure completing a trip. What's the difference between the fuel in your tank and the fuel in a separate can?
OK !Separate. Secure it - like any other cargo - so it can't spill. It is no more or less flammable in one plastic container vs another.
Must be Illinois logic... ;-)
I remember as a kid, having to quickly switch between tanks when the engine began to sputter.Before large main fuel tanks in boats back in the day, it was standard practice to run multiple 6 gallon portable tanks through a mechanical brass 3 or 4 way selector valve. Plumb some fuel line from the valve with a fuel connector fitting to plug it into a standard marine 6 gallon fuel tank. (carry as many as you want). When your main fuel tank is running low, switch the selector valve to run your auxiliary fuel tank(s). No siphoning, just plug it in and go. Yes, 1960's thought process that worked very well.
