Display issue
lalexander2142
2025 M22 with digital display. Not wanting to split hairs, just an annoying issue. On the speedometer panel, both in running mode and float mode, water temp and depth doesn't read, just ---. Everything works on garmin screen. Is this normal. If not, any ideas other easy fix? Dealer either doesn't know or whatever. Picture 1000009152.jpgattached.
My assumption is that the Garmin is getting its info obviously from the transducer that is connected to it, but the speedometer display will just be getting info from motor NMEA connector? Just my guess, not sure if there's an output from the Garmin to the display screen.
