Fibersteel boat lift
Rockie69
Iowa
Ok... I got a lift... Only thing is that it is not set up for a tri-toon. I have found the brackets and angle iron, I just need the bunk boards. Sounds simple right?
Nope... With my marina it is mandatory that the boards be the same as every other lift on the dock. Anyone know where Fibersteel gets their bunk boards? I've contacted Fibersteel and they are not responding. (Probably a little busy right now in LOTO).
Anyone know where they source their bunk boards from? I found two potential sources and I have requested samples.
http://www.ultimatebunkboards.com/index.html
http://epsplasticlumber.com/index.cfm/page/marine/dock--marina.cfm
Thanks!
Thanks!
Rockie69, would you mind telling me the source of your brackets for the toons? I'm in the process on converting my lift for a tritoon as well.
Great...thanks! I'll give them a call today.
