Geoffrey & Brenda
tut, first let me welcome you to the club!
Now, about that fuel gauge, before you go replacing that sending unit, you should be aware that when the boat is on the water it will sit bow up, in other words, not level. This allows fuel to run to the back of the tank, away from the float. This may be part of your problem.
Try putting a few people on the bow, and see if that makes a difference.
As far as the clip you mentioned, it should come out with the use of a small screwdriver to pry it out of the connector. But if you do hard wire it, be sure to use good quality heat shrink type connectors.
If/when you replace the sender, get an ohm meter and make some comparisons between the two, float down, 1/4 up, 1/2 up etc. This way you will know if the sender is the problem.
Of course i would be remiss if i didn't ask, has your dealers service department looked into this for you? You did say this was a new boat, let them have a look at it for you
Let us know how it turns out!
