I know there are a bunch of great solutions here, but I would like to add what I know too, since this was very frustrating on our boat when we had to get gas. It finally reached the point where it really needed a solid solution for our 2013 22SSX when it took a combination of the fuel-dock guys, me, plus service tech guys 45 minutes to add just 4 gallons of gas to our half-full 30-gallon tank because the pump kept kicking off. My dealer had never seen anything like this. I did some online research, the dealer tried some things, then the dealer finally contacted Bennington to get a final solution.
I'm extremely pleased to say that has been multiple years ago now, and no fuel-fill problems have ever since come back to plague us.
Apparently, Bennington determined our particular boat was equipped with a simple Attwood Marine filler, but the overflow spring/cap assembly component had a spring tension that was too strong so it was causing splash-backs in the filler neck that caused the pump to keep kicking off. Sometimes (by chance) the fuel would go in a little better, depending on multiple concurrent variables (angle, flow rate, ...), but the solution was a simple new spring/cap with a lower tension strength. I also found out that apparently different models, and different years, might have different fuel fills, so your results may vary.
There are several great solutions here - so if you do have any fuel-fill issues, know there is hope. Good luck!
