Fuse location
Rbuckalew
Boat started but wouldn't run. Went back squeezed gas bulb and came back to start boat. Now it will not respond to key in ignition. Maybe a fuse? Where is fuse panel located. Model is 2050 pontoon
thanks in advance
What year is the boat and what motor?
You didn't by chance pull the safety lanyard from switch did you?
I did checking it but put it back. Nothing is coming on now. Checking battery terminals now. Got me stumped
Pop it on and a couple times and make sure you got the clip in correctly. Sounds like the safety switch. Might be some corrosion in the safety switch.
