Well I did the install the Garmin 541S over the last couple of days. Pulling the wires thru the underside of the boat proved to be less difficult that I thought. Just need someone skilled with a fish tape or 9 gauge wire to hit the right spot. I ended up using a small air powered sawzall to starts. It worked fine until the blade got really hot. Then it just wanted to melt the plastic. It turns out the plastic in the area is fairly thin. I finished with a sharp utility knife. Scored the lines a few times and a little wiggle and it snapped right off. I will warn you that when I say it just fits..... I mean it! I had to do a little reinforcing on the underside as it dies not take much pressure to weaken the plastic to the point it will crack.
I will need to pull to more wires from the motor to the front of the boat to hook up the command link to my Garmin. This will give me the ability to view engine data on the Garmin. I had to buy a MARETRON MARE-002 N2K TO YAMAHA COMMAND LINK ADAPTER for $123 in order to hook this up. The adapter is only 3 feet long so I will need to splice in about 10 foot of wire to make it work. Once that is complete I should be all set.
