Merc Verado has 2 holes, 2 slots. Remove 2 top bolts, loosen 2 in the bottom slots, and a floor jack with wood blocks does it. A chain hoist on the top lifting ring is easier.
so what is the basic physics around raising the motor up?
this will generate more RPM's?
is the boat usually rigged by the dealer with the motor all the way down?
has anyone out there with a similar Yamaha 200hp 2.8L and eplictal ESP pkg raised the motor up with positive results?
Less motor in the water = less hydrodynamic drag.
Yes, less drag = more speed & higher RPM
There is not a right or wrong answer as to where to mount the engine.
The upside to the lower location is that the engine will resist cavitation better in turns. Some operators do not want to be burdened with needing to trim down in turns to prevent this "blow out" while others will go to the nth degree for an additional mph.
