Has anyone used SharkHyde - like it - hate it???
wetvette
Have any of you used 'Shark Hyde' on your toons, it's pricey but if it works and keeps it looking new
I'll be running out to get some. Input on this would be appreciated. How long can I expect it to last?
Will fenders rub it off? I plan on my pontoon staying in the water a lot.
Thanks for all pro - con info.
Tom
It works great. I had it put on my last toon and after 4 years was about due for a recoat but mine gets trailered to and from the water every weekend. I can't see an investment of this size sitting in the water and getting crusty. It will rub off if things directly rub against it but it is easy to put on. It is self etching which means no prep needed to go over areas already coated with it. I put it on my new toon as well. It is so nice to be able to just use water to wipe things clean or a pressure washer to get any sort of things that may have latched on.
