I've got a 2575 RFS 6.2L 320HP i/o Mercruiser with Bravo III drive Tri-Toon and everytime I pull a tuber or make sharp turns, the engine compartment fills with water. I have had a qualified mechanic check every possible thing he could think of with no obvious problems found. He checked the bellows and even filled the compartment with water while on the trailer. He couldn't find a leak. I noticed while tubing that there is a tremendous amount of water flowing between the tritoons while moving. I also noticed small openings in the aluminum shield directly below the marine plywood deck that runs between the toons toward the front of the engine compartment. These openings might be approx 3/8"x3". Are they responsible for all the water entering the engine compartment? I'm not even certain water would enter the compartment through these openings. The water entering is enough to make the bilge pump to run constantly while pulling tubers. the engine also loses power it seems and sounds bad when the compartment fills with water. Why is this? is it due to the bateries getting wet? What can I do to resolve this problem? Keep in mind, this problem never arises untill I make sharp turns. I'm feeling helpless and I desperately want to fix the problem and go tubing more!
