Planning my first oil change (Yamaha 150 4 stroke) on my new 24 Sli very soon.  I am right at 20 hours on the engine.  My Eagle Lift and slip are too short (25') to get to the engine for my oil change.  My neighbor has a 28' slip that he keeps his G3 tritoon on that I can use for my service work.  My lift has 3 v-shaped bunks that match the tritoons.  His dock has about 6 carpeted flat bunks that are laid 90 degrees to the slip centerline direction and would contact all 3 toons at the same time as the lift is aired up.  The v-shaped protrusions on the bottom of my toons look like they could be damaged if they supported the entire weight of the 24 Sli with this lift setup.  Any experience with this type of lift, ideas or suggestions would be appreciated.
