Lift
AVM
After lifting tritoon, realized the center tube supports broke off of the lift. The boat is being supported by outer tubes.
It will be a week before the lift can be repaired. Is it ok to support the tritoon by outside tubes?
It should be absolutely okay. It is okay to have an under-floor supported lift, sea legs, etc…, and in those situations ALL pontoons hang unsupported. Just having that one unsupported should not be any issue at all on a lift. Different matter if it were a trailer and bouncing with road for any distance or rough terrain.
