PYC5 Dave
- Messages
- 139
- Reaction score
- 98
This is an issue that I thought someone may have already solved as I am still working on a solution. I have lifting strakes on my elliptical pontoons and when I put the boat in and out of the water with straps they hang up on the strakes. The straps when loose are bell shaped or curved. So when the boat is in the water the strap hugs the pontoon AFT of the strake. When I lowered the boat the boat floats and I try to push it back the straps get hung up on the lifting strakes. Lowering the straps a little more helps but my wife and I on opposite sides still fight pushing them down to clear the lifting strake. I have tried using a boat hook but that gets caught under the strake. Going to try a PVC pipe and "T" next. The same issue occurs when coming into the slings at the bow, but a bunch of jiggling and standing on the bow seems to fix it. I am sure I can over engineer a solution with weights and pulleys but though I may already have an answer here. Thanks
