Lights not working 2015 Bennington
Kevkosek
I purchased a 2015 Bennington tritoon new 11 months ago.  It has around 40 hours of use, almost entirely daytime.  I noticed the other night that neither dock light or the green nav light are working.  The red nav light, push-button interior light, top light, and blue Bimini lights all work fine.  I pressed reset button but that did not correct the problem.  These lights have been very rarely used.  Ideas/suggestions?
Are they the stainless lights or plastic? The stainless are leds and plastic are incandescent bulbs. Also the docking lights are on a separate switch.
Sound like a grounding problem or wiring connection problem at the light. If you can't figure it out,warranty will cover it. Good luck!
