Need input of owners smarter than me....
stbentoak
2015 QCW fixed tower boat 200 HP 4cyl Yamaha. Overall been a great boat!
#1 Where we boat on a river it is very weedy/shallow late in the year. Prop gets wrapped almost every time out as we cross shallow sections to get to deep sections. Should I trim up to go thru weedy areas? Go faster or slower? Or live with it and do the best we can?
#2 Along with the above, my intakes for the impeller cooling water get plugged about 40% of the time and the motor beeps for about 30-60 sec while I reverse and try to wash the ports clean. Does this beeping hurt anything? Reversing seems to clear it well enough, and it never actually stops "peeing" But a constant worry when we sometime are far from port. Anything I can do with the intakes to make the less susceptible to plugging?
#3 Lastly, I have a Garmin basic "Fish" depth finder that does work well but would like to have a "Simrad" type of unit that I could plot a course on and then stick to it relatively closely.. especially for night boating. I realize I may not get this built into the dashboard, but has anyone done an arm mount one and how hard is it to install? Any unit/arm combo that anyone would recommend? Would this have to be Dealer installed? Thanks for all responses and insight!
In the areas that we have that are simiular to what you are dealing with, I trim up and go slower . I'm sure others have different opinions .
My question is how often do you change your impeller ?.
There are several ,members here that have mounted an additional Simrad or Garmin , on a Ram Mount or simiular . You should be able to do that yourself.
#1 For weeds trim up and go slow except when you put it into reverse to clear the prop.
#2 Yamaha intakes are kind of fine and get plugged with the a certain type of weed and time of the year. I have thought about cleaning intakes with a brush on a stick but then the season passes. My previous Honda was less sensitive to intake plugging but then the pee hole would plug. I have had to listen to the beeping for up to a minute without further problem. Yamahas are kind of idiot proof unless you are a complete idiot. You are smart to keep an eye on the peeing.
#3 I replaced my basic Garmin fish finder with a same size Garmin lake map GPS/fish finder. The screen is kind of small but big enough as long as I do not split the screen for both functions.
We live on a canal that connects to our lake. The canal is a dead end and we're the third house from the south end.
The city weed cuts in the canal every week but the problem we have is the duckweed that forms a carpet.
I have a Yamaha motor and can confirm that the intake screen has very narrow openings. My old boat an my neighbor had Mercury motors and never had a problem. I would love to find some intake screens with slightly bigger openings. I've even thought of buying a 3D printer to make my own.
I use an extendable painters pole with a stiff brush on the end. After every outing I immediately clean the intake openings. You do NOT want to let the junk harden in the intake screens. It is much harder to remove if that happens.
When I go out I trim the motor up until I'm in deeper water.
I have had the high temperature alarm go off a couple of times. I clear the weeds, reverse and proceed.
I've recently engaged with the city, who maintains the canal. I don't have much confidence that they will address the issue.
The attached photo is from this week...a particularly bad day. I and my neighbor do run water aerators and it helps a little.
