McZiggy
With the trim close to 3/4 of the way back and nobody sitting in front of me, the spray from the pontoons don't start until about a 1/3 of the way from the front. With the trim down all the way, water splashes up against the shield things on the very front of the pontoons. It seems as if I'm getting the nose cones out of the water enough, just lack the grunt to get me up that little bit. From all the reading I've been doing, the larger diameter & blade area of the new SS prop should get me there. If it doesn't, I'll be raising the motor to the 2nd hole from the bottom. It seems to me that the express tube really sits the rear of the boat far down in the water, and that with the engine in the lowest position, it's setup for a regular 2 toon.
