G
Geewest
Guest
I’m testing out this new light weight Aluminum Box Style anchor this weekend. It weighs 12 lbs (a box or slide anchor the same size weighs over 30 lbs) and it go's from collapsed to assembled in 12 second's.
(im sure you could do it faster but that's what it to me the put it together the 2nd time I played with it) It collapses in 7 seconds.
"The Leader". The round metal bar @ the front of the Anchor seems to be where all the weight is. So it could even weigh less if that was made from Aluminum. But 12 Lbs seam's Very reasonable compared to 30lbs for the slide anchor.
The goal was to get a lighter/easier to handle box anchor. My Small box anchors make me very nervous when taking them in and out of the water when it comes to messing up the boat. They are not light and that makes it easy for them to swing where you don't want them and cause damage.
I will let you know how this one works out
Folded
Apart
Assembled
Folded
Apart
Assembled
