mattpoinsett
On a related note what type of boat lift do most use? I will leave on a lift from 4/15 to 11/1 during the year. Looking a a Shorestation with the Toon rails.
I only put the bimini up once ( day we brought it home ) . It rattled when closed and wrapped with the boot . Dealer had a fix but I sold it before it was installedMine does too. However, since we don’t put it up very often, that is a non-factor for us. And when it is up, we are usually anchored and lounging/swimming, or maybe slow cruising with company (but even then it is rarely up). If we want a lot of shade, we hang out lakeside on our deck and patio umbrella. Ha, ha.
But for some that want their bimini up as much as possible when boating, this may be an issue. It is rated for 30 mph, but like you said, has a rattle to it as you move above 25 mph or so. The rattle does not inspire confidence when going a little faster…
Yikes. Something wasn’t installed right on that one. Ours is solid when closed and wrapped in the boot. Looks sharp too in the radar position. Sorry your’s was a dud.I only put the bimini up once ( day we brought it home ) . It rattled when closed and wrapped with the boot . Dealer had a fix but I sold it before it was installed
Their fix would have stopped the back from falling ( unless you have someone to hold it ) when removing the boot too , that is main reason I went no power on the 2022Yikes. Something wasn’t installed right on that one. Ours is solid when closed and wrapped in the boot. Looks sharp too in the radar position. Sorry your’s was a dud.
Believe its just included on the Yamaha pre rig, and not the Merc..Isn't the water fuel separator large normally included with the outboard? It's small potatoes cost in the grand scheme of things.
I have a Shoremaster 5500lb with pontoon kit (side rails and 3 sets of bunks) for my 23SSRCX. Works well. Not cheap though unfortunately.On a related note what type of boat lift do most use? I will leave on a lift from 4/15 to 11/1 during the year. Looking a a Shorestation with the Toon rails.
