One Speaker Not Working
ErinnDan
Sarartoga Lake, Saratoga Springs, NY.
We have one speaker not working under a bench seat. I pulled everything out of there and made sure everything behind the speaker was connected, which it was. Not sure where to look next. Any thoughts?
Actually any speaker will do for a test, car audio, bookshelf, etc. You can also look under the helm to make sure they are connected, just note the wire colors at the speaker for reference when you get under the helm
Just take the speaker out, put your tongue across the terminals, and have someone yell directly into the othe side of the speaker. If you feel a slight shock, the speaker is fine.
Can you post video of you doing this?
Just take a small battery. (Regular household) and hook it up to the + & -. It should push the cone out if hooked up correctly.
