power steering addition
lakebum
Hot Springs, AR
Just helped Zodapop bleed his new power steering addition. Seems to work great on the trailer. Maybe he will post pics of the install. His Q with a 250 and just hydraulic steering was tough to handle at speed. Steve
You can't beat power steering with a big motor.
That $800 is for power steering? And not just hydraulic steering?
$800 is just for the Teleflex Marine Seastar Hydraulic Steering Kit. You've also got to order a pair of SeaStar hoses which are around $5.00 per foot apiece--$100 average cost.
Now the Seastar Tilt Classic Hydraulic Steering Kit (Large) will set you back $1,200 minus hoses.
The Teleflex Marine ss 12Volt/24Volt 15 Feet Harness Pro Power Assist Unit (Large) is almost $1,900--and it's the power steering pump.
Most will add a second battery and a Perko battery switch to link them--$200 for the pair.
Grand total for adding SeaStar hydraulic steering, the power steering pump and another battery will set you back between $3500 and $4000 with labor included.
That makes my Yamaha F150 w/o power steering much more attractive. From what I can tell, I'm only giving up between 3 and 6 mph to the F250 motors.
Wow. Lots of money. I guess I'm glad I've never been on a boat with the power steering. I have always had hydraulic. Even with twin 150's on my last boat but they were counter rotating. Then again I, I wasn't carving turns and pulling skiers and tubers all day..
Adding the power steering pump to our boat cost a total of $750.00. Got the pump on Craigslist for $600.00,and hoses, making a bracket etc was the rest, and I was the labor. I wouldn't own another boat without it.
Ditto to Carl's statement! What a difference!
There you go Carl. I know pumps show up on EBayMotors.com from time to time at lower prices.
If I can say something positive about Verado motors, they at least have a Mercury power steering pump that's much more reasonably priced than the Teleflex power steering. I don't know if the Merc. pump will also work on the new 150 hp FourStroke motor, however.
Zodapop's unit came with everything necessary to install it for $700. The extra 100 was for aircraft grade fluid and different fittings to make a nicer install. Actual price was closer to $750. Like Carl's, we were the labor. Steve
I test drove one of the Benningtons at the open house in August and it was pretty awesome. I actually opted not to have it factory installed on my 2275 GCW with a Merc 150 HP motor. I figured I would give it a try without it. I'm sure after the first day out I will be on the Internet looking to buy one.
I will have start my research and figure out what's compatible with the new Merc 150 fourstroke motors and the existing seastar unit. I it's approximately $800 or so to do it myself I will be interested.
My wife thinks she will learn how to drive this thing, she only drove our old boat once ten years ago and ran it into a shallow area and beached it. She's starting to get the courage up to try it and the power steering would really benefit her.
