Chris Z
I always wander back and forth between the desire for a stainless prop and the reality of my boating environment. With the last boat I stayed with aluminum and was very pleased after some surprising bottom strikes (sand bars everywhere).
Once again with the new boat, and a larger motor (115 to 150), I'm thinking about whether or not the performance at the top end is worth the added expense and risk of expensive repairs that could come along with a blade strike.
Also factoring in is the Yamaha outboard's distaste for spinning a heavy prop. This shows up as an annoying ticking at and just above idle as the splines just below the power head load and unload. It does go away once you load up the outboard a bit with some throttle but if you're out for a sunset cruise and have the slightest hint of OCD you'll hate it as soon as you hear it.
And, my dealer also has mentioned something called Black Steel as a prop material. He claims it carries the blade stiffness of stainless with the lightness of aluminum. That takes care of one issue... but.
So, once again the solution is clear as mud to me. He's going to prep the boat with an aluminum prop for delivery but I figured I'd do a little research here to gather some opinions. I notice in the pictures many of you are opting for stainless props.
Thoughts?
CZ
Thoughts?
CZ
