When I created a build if you added the Pop Up Cleats the HD Rub rail was required. Some how they go together. I believe you can add the HD rail without the Cleats. You refer to the corner cleat as a casting but I do not know how it would interface with the HD rail. Maybe there is more to the HD Rail than the rubber strip that is added to the rail and extrusion. Maybe if I study the photos it may be clearer.Wow, I'm sorry it's too late to modify your order. Our dealer told us we have up to 30 days prior to build date, to modify. I noticed pop up cleats are now available too. Are the corner cleat castings a separate build item or part of a rub rail upgrade?
