I just got an 08 Bennington 2275 and the green running light burned out. I have read about the LED bulbs and would like to replace mine with those. However, access to just get to the dang bulb is a bummer. Do the 2 little screws around the base of the lens holder itself come out (mine do not, just keep twisting), and will this give me access to the bulbs ? I have the white/beige large plastic "corner" pieces that the running lights sit on top of (no docking lights). I can't even get the larger ss screws holding that plastic piece to come out, even though it seems like the nut piece underneath is indeed firm into the bottom of the wood decking with the little tips that dig into the wood ???
What is the trick to getting the running lights off of the plastic please, and same for getting the large plastic corner light assembly pieces off of the decking (in case I wanted to put some dock lights up there as well) ? IF I do put on dock lights, what types/sources are recommended please, and would they just attach on top of the plastic corner pieces similar to the running lights, or are they more "internal" to the plastic piece or somewhere else ? Also, which of the Accy panel toggle switches should docking lights be wired to ?
Thanks,
FRD
Thanks,
FRD
