Dan S
I'm at the point where I'm purchasing a trailer for my 21SLX with a 115 Yamaha with undersheeting and open strakes. Originally I was going to purchase a bunk trailer but I don't have the height through the doors on my pole building so scissor trailer here I come. I'm going to purchase a trophy trailer. The only question is should I purchase their 22-45 or the 22-47. The only difference between the two is the longitudinal supports that the boat rests on are 2" further apart on the 47. At first glance that seemed the way to go. However there's only 52" of space between the pontoons leaving only 5" of space and some of that is taken up by the vertical rollers that run from front to back for the toons to roll against. Near as I can calculate, if I go with the 47, I'll have only 1-2" of space between the toons and the rollers - pretty tight. The other issue is that the distance between the outside sidewalls of the 2 tires on each axle is 48". That's only 2" from the tire to the toons/strakes, if I get the boat exactly centered on the trailer every time. What widths have some of you used? Anyone used the 45" or 47". Thanks
