mad4sax
38 degrees and snowing on May 15th.
Not a happy boater. :-(
https://www.instagram.com/p/BFcEpMhxMeW/
I'm in CNY also and these are days when my wife and I look at each other and ask why we are not in North Carolina yet.
Current temp Lake Front 41 F in Ohio
Freeze Warning has been posted for tonight
Boat Is In The Water
Do I need to worry about the Yamaha 90 HP with temps down to 27 F
I always have motor and prop raised out of water when docked
I am sure the Lake will not freeze
Concerned about water in motor freezing and causing damage
Tomorrow temps 63F
Freeze Warning
East Central Ohio
Low temperatures, will range from the mid 20s in the highest ridges, and from 29 to 32 elsewhere ... Impacts: unprotected outdoor plants will likely be damaged or killed.
2 hours ago – National Weather Service
Mad4sax, I'm on the north end. We bought the boat from Owasco Marine and love those guys. We were thinking of putting it in the water at Owasco but preferred the bigger lake and the ability to get over to Seneca lake by the canal. We have the 22 SSX with the dual stern gates and unless tubing will likely always see a bunch of poles off the back. Also has lifting strakes. Metallic sorrel color with a Yamaha 115. As for me, you can't miss me...I'm the portly guy with the goatee.
Hope to see you out there when the weather gets warmer!
