Butchkid
I decided I needed a spotlight since I was boating at night so often, and there are always crazy people on the water sitting without realizing their anchor light is off. It's also possible they do realize it and don't care. Either way my docking lights weren't designed to light up the night, and so I needed a strong spotlight. I went to Lowes and found the Stanley 2M Spotlight. It is 2 million candle power or 1365 Lumen. It plugs in to the 12v on the boat which keeps it charged. This thing will give you a sun tan at midnight if you aren't careful with it. The one drawback is that it is definitely not a flashlight. You can't keep it on for long periods of time because the battery will go dead quickly. It's not really designed for that. I plug it in and keep it sitting by my feet while I'm cruising at night, and if I see something in the darkness I can immediately spot it. It's cheap ($25), and for spotting works really well. I would suggest a flashlight as well though because it is simply too bright to use on the boat for normal lighting purposes.
